Anybody know the fitting type for LS1 Camaro fuel filter?
PostPosted: Sat Apr 21, 2012 3:01 pm    Post subject: Anybody know the fitting type for LS1 Camaro fuel filter? Reply with quote
I'm having difficulty being able to determine what I need. These are examples of fittings I have with o-rings in different locations. The one on the right screws right in and might seal against a hole deep in the connection. The one on the left is too big so I can't test fit it, but it might seal to a very small groove at top of fitting.
Anybody know which is correct? I need to order a tee for return line but don't know which style to get. Thanks.
PostPosted: Sat Apr 28, 2012 12:35 pm    Post subject: Reply with quote
It appears that the fitting to fuel filter is 16mm x 1.5 and is of the style on the right side of picture above.
PostPosted: Sat Apr 28, 2012 5:42 pm    Post subject: Reply with quote
I'll be damned... I've had the right fittings the whole time. The fittings for LS1 F-body fuel filter and fuel return t-block are the same as the TPI fuel rail adapters I already have (ACCEL p/n 74730). This just slashed $25 from my budget! Very Happy
PostPosted: Sat Apr 28, 2012 5:53 pm    Post subject: Reply with quote
Jon, do you guy's not have an oil filter service place out there? Around here we just go to William's and get any type of crazy fittings like that. The one on the right looks like a Saginaw box fitting. Laughing
PostPosted: Sat Apr 28, 2012 6:41 pm    Post subject: Reply with quote
No, I've never noticed a shop like that. But maybe I just haven't looked. I'll keep my eyes open. Thanks!
PostPosted: Sat Apr 28, 2012 6:48 pm    Post subject: Reply with quote
I haven't seen one over here in Kitsap either, but I've found fittings and hoses that I've needed at a hydraulic hose shop. The local one here is Belfair Hose - they made up my braided brake lines while I waited.
PostPosted: Sun Apr 29, 2012 8:08 am    Post subject: Reply with quote
Williams is good. We also have Western Fluid Components who carries alot of metric fittings, but can be pretty spendy.
