91camaro_rs Member
Posted: Wed Feb 01, 2012 1:20 am Post subject: power steering pump or just the hoses |
my power steering hoses leak so i need some new ones that dont, i have a 350 tpi with serpentine
if you have a whole pump with both hoses that would be better _________________
Posted: Wed Feb 01, 2012 9:36 am Post subject: |
Mine leaks too. The high pressure hose (the one with the crimped fitting at the steering box) is like $25 at NAPA.
You might check to see if the O-rings on the hoses are worn out. _________________ 92 Camaro
Red92Bird New Member
1992 Pontiac Firebird
Posted: Wed Apr 25, 2012 6:11 pm Post subject: |
If you are still looking for the powersteering pump and hoses i have them. from a 91 firebird.. make offer _________________ 92 Bird l03, 700R4, 10 bolt 3.42 eaton posi. 275/40/17's |
91camaro_rs Member
Posted: Thu Apr 26, 2012 8:46 am Post subject: |
yeah im still in need of one, dont have a lot of cash at the moment so once i get paid next week ill check back in with ya _________________
Posted: Thu Apr 26, 2012 9:32 am Post subject: |
I just bought a PS hose kit for like $20 at O'reilly. _________________ 84 Camaro Z28 - LS1/T56
Posted: Thu Apr 26, 2012 11:01 am Post subject: |
I need it outta here so lemme know what you can do. $20 sound ok?? _________________ 92 Bird l03, 700R4, 10 bolt 3.42 eaton posi. 275/40/17's |
91camaro_rs Member
Posted: Thu Apr 26, 2012 7:25 pm Post subject: |
$20 is fine, does it leak or anything? _________________
Posted: Fri Apr 27, 2012 12:04 am Post subject: |
i dont remember seeing anything. however i will check it out tomorrow in the daylight and make sure everything is in good shape. its still hooked up so it will be easy to see any leaks. _________________ 92 Bird l03, 700R4, 10 bolt 3.42 eaton posi. 275/40/17's |
