OK... TC replacement time for racing only.
Kage87Z
1969 Chevrolet Camaro
PostPosted: Sat Apr 07, 2012 2:35 pm    Post subject: OK... TC replacement time for racing only. Reply with quote
In my 85 383, I understand (based on the paper work) that the heads were done very well on the carbed 383.
I topped out at 109 at PIR last year, and that's with a stock converter that did not like that at all.... and a stock cam.
I'm keeping this car race only. Right now, it's got a 4.10 open rear end and a turbo 350.
So, it's time for another converter. It's also time for a cam.
How high do I go for the stall? I was thinking in terms of 3500 or so. This is for racing only.
Suggestions?
Todd Beamer - 9/11
Never Forget
PostPosted: Sat Apr 07, 2012 6:30 pm    Post subject: Reply with quote
I would talk to whoever you get the cam from, they should be able to recomend a stall speed that matches the cams power range.
PostPosted: Sat Apr 07, 2012 7:14 pm    Post subject: Reply with quote
I would give a call to A-1 transmission in Vancouver. They do a pretty good job at spec'ing a converter and they custom make them as well. However, I'd advise you to get a locker/posi/spool before a different cam. The better you can hook up, the better your ET's will be.
PostPosted: Sat Apr 07, 2012 7:56 pm    Post subject: Reply with quote
That's a whopper of a trap speed for stock cam and converter. Cool
Kage87Z
PostPosted: Sun Apr 08, 2012 3:50 pm    Post subject: Reply with quote
It is. This was the 3rd or 4th time I'd gone down the strip. The video speaks for itself, though; wife is doing the voice-over.
http://www.youtube.com/watch?v=9KfSrVo1jMM
The converter is leaking like a sieve and I've just about got it out.
I bought the car from a former Crewbie, who gave me the low-down:
Stock coverter and stock cam.
Any suggestions for a race-only cam set up?
Todd Beamer - 9/11
Never Forget
PostPosted: Sun Apr 08, 2012 4:33 pm    Post subject: Reply with quote
LMAO Sorry man, your wife's lack of confidence cracked me up.
Is this the same car?
http://cascadecrew.org/phpBB2/garage.php?mode=view_vehicle&CID=23
Kage87Z
PostPosted: Sun Apr 08, 2012 6:04 pm    Post subject: Reply with quote
It is!
And now, my wife is the one doggin' me to get this thing back up and running.
Todd Beamer - 9/11
Never Forget
PostPosted: Mon Apr 09, 2012 11:03 am    Post subject: Reply with quote
Stock cam 383? WTF does that mean.
http://www.ctconverters.com/index.html
I prefer Continental converters. Or buck up and buy a Vigilante.
Kage87Z
PostPosted: Mon Apr 09, 2012 5:15 pm    Post subject: Reply with quote
Far as I know, it means that it's the same roller cam that came with the 350.
Thus, stock camshaft.
Thanks for the tip on the TC's.
Todd Beamer - 9/11
Never Forget
RK82
1982 Pontiac Trans Am
PostPosted: Mon Apr 09, 2012 8:03 pm    Post subject: Reply with quote
that's what I was thinking, who puts a stock cam in a 383
Kage87Z
PostPosted: Mon Apr 09, 2012 9:35 pm    Post subject: Reply with quote
Uhhh.... the guy I bought it from?
Todd Beamer - 9/11
Never Forget
izcain
9sec Club
PostPosted: Tue Apr 10, 2012 8:27 pm    Post subject: Reply with quote
Never spec a tc without knowing the combo on the engine. If you plan on changing the cam change that and get the engine buttoned up then spec that TC
9.17 @ 148
PostPosted: Tue Apr 10, 2012 9:29 pm    Post subject: Reply with quote
I'm with stupid
Kage87Z
PostPosted: Wed Apr 11, 2012 11:06 pm    Post subject: Reply with quote
OK... going with a GM30 TC... and XE274 cam, beehive springs and new retainers...
The engine aspect is kinda like this guys:
Also looking at this:
Brand Lunati
Manufacturer's Part Number 50156
Part Type Camshafts
Product Line Lunati Hydraulic Roller Tappet Camshafts
Summit Racing Part Number LUN-50156
UPC 090127459133
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,000-6,500
Intake Duration at 050 inch Lift 232
Exhaust Duration at 050 inch Lift 242
Duration at 050 inch Lift 232 int./242 exh.
Advertised Intake Duration 290
Advertised Exhaust Duration 300
Advertised Duration 290 int./300 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.525 in.
Valve Lift with Factory Rocker Arm Ratio 0.510 int./0.525 exh.
Lobe Separation (degrees) 110
Computer-Controlled Compatible Yes
Grind Number RRA1-232-242
Valve Springs Required Yes
Quantity Sold individually.
s:
Todd Beamer - 9/11
Never Forget
redlava
PostPosted: Thu Apr 12, 2012 1:15 pm    Post subject: Reply with quote
I bought a street edge converter 2800rpm, I have driven the car a few times since I have had it installed. It definatly wakes the car up. I havent really had the car out to much since it was installed so I can not comment on its durablity. Based on the reviews, I saw it should hold up well, it ran about $550. Definatly had a seat of your pants improvement and im running a smaller cam than you plan to.
