BluFbdy Member
Posted: Thu Feb 23, 2012 4:43 pm Post subject: |
blue89 wrote: | Turned out good! Especially for your first box. Not gonna lie though, i liked the zebra. Once you get it powered you will find out how well you did your seams. |
The zebra will make a reappearance soon I just didn't want to be bleeding on it so I waited, the seams should be solid I coated the outside of the box with resin and let it seep into and spots I felt would leak, and the inside got a bondo/resin coat around the top seam _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Thu Feb 23, 2012 9:34 pm Post subject: |
Okay good. I usually douse the wood down before i lay glass down on it. Reson sticks pretty good. |
BluFbdy Member
Posted: Thu Feb 23, 2012 9:39 pm Post subject: |
Yeah I kept laying resin down until the mdf was a nice dark color I didn't want it to break down if it ever got wet, since my hatch likes to leak and having the box molded in I'd probably never bother to look if it happened to leak _________________ If you expect a kick to the balls and get a slap to the face its still a victory
BluFbdy Member
Posted: Sat Mar 03, 2012 11:09 am Post subject: |
made some progress, zebra print was jacked for another job so I opted for some white vinyl for the center just gotta throw it in and then bring myself to do the trim portion
think they're bright enough? lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Sat Mar 03, 2012 1:59 pm Post subject: |
Not bad. When are you putting it in? |
BluFbdy Member
Posted: Sat Mar 03, 2012 2:31 pm Post subject: |
today if I have time, I need to suck the remaining water from my well and just load it in, ill run without a trim for now I got a new hatch from Luke so hopefully it stays dry.now _________________ If you expect a kick to the balls and get a slap to the face its still a victory
BluFbdy Member
Posted: Sat Mar 03, 2012 10:24 pm Post subject: |
Managed to get the box in, just used my old settings on my amp and it can beat the snot out of someones head. I'm loving it, definitely want to turn down my gains though my bass knob is always down under half, anything more and its overkill.
The bass has gained a lot more punch to it, definitely found what I was missing _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Sun Mar 04, 2012 8:46 pm Post subject: |
Have to love hatch backs. Installed pic? |
BluFbdy Member
Posted: Thu Mar 08, 2012 12:13 am Post subject: |
sorry it took a few days I've been slam busy at work and pictures at night are no good because the LEDs
still need to build my trim but I like it _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Thu Mar 08, 2012 8:35 am Post subject: |
Looks good. Wasnt expecting it to sit so low. You could almost do a false bottom to make your trunk area flat? |
BluFbdy Member
Posted: Thu Mar 08, 2012 1:05 pm Post subject: |
blue89 wrote: | Looks good. Wasnt expecting it to sit so low. You could almost do a false bottom to make your trunk area flat? |
yuuup I could lol but that would hide all my hard work lol I wanted a solid box that could allow me to us my t top bag because I don't like putting themin my backseat, the bag can clear the subs by 2 or 3 inches so I achieved my goal _________________ If you expect a kick to the balls and get a slap to the face its still a victory
nonsensekid20 Member
Posted: Thu Mar 15, 2012 5:50 pm Post subject: |
Man you need an LED in the well light. Looks like it's dimming a lot from the LEDs in the box. |
BluFbdy Member
Posted: Thu Mar 15, 2012 6:38 pm Post subject: |
I took the trunk light out, the LEDs draw milliamps at the most lol since the new box and the rewire my voltage quit jumping around I can have my music all the way up at idle with minimal voltage drop, maybe half a volt at the most _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Thu Mar 15, 2012 7:49 pm Post subject: |
nonsensekid20 wrote: | Looks like it's dimming a lot from the LEDs in the box. |
Wut?
*Edit: I realize now Andy beat me to the punch on it, but LED's don't draw beans. |
Posted: Thu Mar 15, 2012 7:57 pm Post subject: |
I believe he means that the light is very dim compared to the bright LED"s.. |
BluFbdy Member
Posted: Thu Mar 15, 2012 8:55 pm Post subject: |
chevymad wrote: | I believe he means that the light is very dim compared to the bright LED"s.. |
yeah we will go with that lol I still haven't had my vinyls made to poof can the plexi but I'm like mid move right now so that's waiting lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Richster Magic Fingers
Posted: Fri Mar 16, 2012 9:29 pm Post subject: |
Looks very good! _________________
