Posted: Sun Oct 23, 2011 10:29 am Post subject: Anyone have a 91 tpi harness and ecm? |
Been working on a tbi to tpi swap.. Just discovered that the c100 and c207 connectors are completly different.. Would basically need to build the harness from scratch almost. So Flea and I would like to find a matching setup. |
BluFbdy Member
Posted: Fri Nov 11, 2011 10:39 am Post subject: |
I had to get my harness from thirdgen ranch, called them and asked for them to look for the specific harness, I got the ecm from Luke and I'm just burning a custom prom for it, you can use any 7730 ecm, v6 and v8s except for Tbi all used them Iirc, I'm working on the same swap I believe you're putting a SD tpi into an older year correct? I have the c207 mostly figured out the c100 is a bit more of a hassle, you'll also have to fees the CSS signal to the ecm a different way if your original speedo is cable _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Fri Nov 11, 2011 6:17 pm Post subject: |
I think we've got parts coming. And no we were trying to put an older maf system in a newer tbi car.. So same difficulties but backwards. So now that he has the SD computer and harness it should be a fairly easy fix. |
flea Member
Posted: Fri Nov 11, 2011 6:31 pm Post subject: |
Got two packages in the mail now, waiting on the third early next week.
Going through with-drawls here, I need my car back. _________________ Killing mailboxes since 2009 |
BluFbdy Member
Posted: Fri Nov 11, 2011 9:06 pm Post subject: |
Lol well when you guys get proficient at it you should help me out I've been stalling because of the wiring and needing new gauges _________________ If you expect a kick to the balls and get a slap to the face its still a victory
