Spark Plug gap help
PostPosted: Wed Oct 12, 2011 2:01 pm    Post subject: Spark Plug gap help Reply with quote
I have a iron 350, with the 113 alumn heads. I have put in the delco plug for the an 89 vette. I think I gapped them at .035.
Ive not drove the car alot, and its starting to get a studder under load. Ive checked my cap n rotor button. I'm thinking I may have gapped the plugs wrong. Is 035 correct? Or should I raise or lower it?
PostPosted: Wed Oct 12, 2011 2:24 pm    Post subject: Reply with quote
Just pulled one out, yes they need replaced.
I have delco FR5LS in it. I'm wondering about putting some of the delco shorties in it since I have headers. Any comments or suggestions on that?
PostPosted: Wed Oct 12, 2011 4:24 pm    Post subject: Reply with quote
Stock ign run .035.
I ran .045 with an MSD and aftermarket coil.
Heat range is going to be more important.
PostPosted: Wed Oct 12, 2011 5:19 pm    Post subject: Reply with quote
I just have an MSD coil.
PostPosted: Wed Oct 12, 2011 7:10 pm    Post subject: Reply with quote
You should be fine with .035.
Misses will start to come on more with too large a gap, than with too small.
PostPosted: Thu Oct 13, 2011 2:33 am    Post subject: Reply with quote
Thats what i was thinking.
Ive replaced them all. I found one that was set to .040 Confused Dunno what I was thinking.
