Posted: Mon Sep 05, 2011 6:13 pm Post subject: Looking for a few things |
- Lower shifter boot
- 5 speed shifter plate
- clutch "petal" pad sourced via parts car
- lightweight flywheel
- drop spindles
- raised strut mounts
- LCA relocation brackets
- Recaro LS seats sourced @ VWvortex
- strut tower brace
- headers and y-pipe sourced @ Dyno Don
- sub frame connectors
- any kind of big brake set up
- Koni or Bilstein struts/shocks rears have been sourced @ eBay
- 3" and 2.25" wheel adapters
- speed density TPI cold air intake
- 5 point roll bar
- 6 bolt steering wheel adapter (MOMO)
- 1 pair chrome 18x9.5 corvette y2k wheels
- stereo amplifier. (800rms)
- stereo head unit. (w/iPod hookup or bluetooth) sourced through friend
- torque arm relocation mount/crossmember
- mig or tig welder
- 4th gen washer fluid tank
- G-body A-arms
I'll have a few more things to add but this is it for now[/b] _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Sep 05, 2011 9:14 pm Post subject: |
Is a lower shift boot worth it's weight in gold yet?
I have a pristine one, but it's going in my car ASAP.
If you're desperate, go on lowes.com and search for this item number: "53196"
That's what I used temporarily 'til I found the lower boot I'm using. It fits almost perfectly. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Sep 05, 2011 9:18 pm Post subject: |
Alphius wrote: | Is a lower shift boot worth it's weight in gold yet?
That's what I used temporarily 'til I found the lower boot I'm using. It fits almost perfectly. |
_________________ 92 Camaro
Posted: Mon Sep 05, 2011 9:21 pm Post subject: |
Man, how are these rare? I had a couple from the JY when I swapped the T-56. Put one in my IROC sold the other. Found a nice one when Gabe was out here (he bought it), and got another good one in the Bananer.
Also, I just sold a good set of pedals with good pads and a five-speed plate to Bruce on Saturday. So yay for bad timing. |
Posted: Tue Sep 06, 2011 7:38 am Post subject: |
aaron_sK wrote: | Man, how are these rare? |
Because GM no longer makes them, 4thgen ones don't fit, they're rubber that's exposed to road grime and oil, and idiots break/tear/remove them when they mess with our cars.
I've been junkyard hopping for years and the ONLY one I've ever seen was the one I bought when we were out together. You must just be lucky, man. _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Sep 06, 2011 5:18 pm Post subject: |
Alphius wrote: | 4thgen ones don't fit, |
Wanna argue about it?
Actually I have never put a fourth gen unit on a factory shifter hole, only a hole I cut, so the holes might not line up or whatever, but the boot worked fine. |
Posted: Tue Sep 06, 2011 6:00 pm Post subject: |
aaron_sK wrote: | Alphius wrote: | 4thgen ones don't fit, |
Hands off on this one, but I hear the 4thgen ones don't even come close to fitting a factory thirdgen shifter hole.
I do believe they are both discontinued from GM anyway. But the 4thgen should be way easier to find at the junkyard. _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Sep 06, 2011 7:00 pm Post subject: |
See, I didn't have a factory hole in my IROC. So I got a fourthgen T-56 unit (different boot for T-5 and T-56 fourthgen, and yes, they are marked) and went with it. |
Posted: Tue Sep 06, 2011 7:01 pm Post subject: |
Indeed they are discontinued, I think I'll do a little research on the 4th gen boots. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
kurfbird Member
Posted: Tue Sep 06, 2011 8:15 pm Post subject: third gens boots |
I have three of these 3rd gen _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
Posted: Tue Sep 06, 2011 8:17 pm Post subject: |
I never liked how my 4thgen boot fit. _________________
Posted: Sun Oct 09, 2011 10:10 pm Post subject: |
Updated the first post with a few things, mostly aftermarket stuff. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
charlie6178 Member
Posted: Mon Oct 10, 2011 6:13 am Post subject: |
I have a set of LS1 rear brakes, and an extra strut tower brace laying around! _________________ 1992 Camaro 1LE Z28 |
Posted: Mon Oct 10, 2011 12:52 pm Post subject: |
Mmm, idk about the LS1 rear brakes, I already have PBR rear brakes which are not far behind LS1's. I'm more interested in front brake set ups. But which STB do you have, any pictures of it? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
izcain 9sec Club
Posted: Mon Nov 28, 2011 8:39 pm Post subject: |
Got a set of hedman full length 1 5/8's but you would have to fab a y pipe for them. _________________
9.17 @ 148 |
Posted: Sat Dec 03, 2011 11:28 am Post subject: |
izcain wrote: | Got a set of hedman full length 1 5/8's but you would have to fab a y pipe for them. |
I guess I need to edit my post. I actually ordered a set of Dyno Don headers and Y-pipe, but thanks for the offer! _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Dec 30, 2011 11:52 pm Post subject: |
Added a few more things. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Jan 19, 2012 8:49 pm Post subject: |
I really need some Koni's, and Recaro's before March. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Jan 27, 2012 11:35 pm Post subject: |
I found some Recaro's locally. Koni's and raised, solid struts mount are the highest on my priority list. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Apr 09, 2012 7:09 pm Post subject: |
Added G-body A-arms to the list. |
