Posted: Wed Aug 24, 2011 7:14 pm Post subject: |
| iansane wrote: | | I have a thirdgen roll bar hoop just sitting at the house in tacompton |
O RLY?
| Al Hasse wrote: | | Welding cable is the way to go. |
I think that's how I will go with mine. I was going to put it in the tire well, but I'm now debating running the it behind the passenger seat like Ian's since everything behind the seats will be gutted anyway. |
Posted: Wed Aug 24, 2011 7:20 pm Post subject: |
| Whoa whoa whoa. Be like me? Are you loco? You're car is going to run away from you. |
Posted: Wed Aug 24, 2011 7:23 pm Post subject: |
| The e-brake totally works great! |
Posted: Wed Aug 24, 2011 9:14 pm Post subject: |
| aaron_sK wrote: | | RSFreak wrote: | Ugh! The stock IROC steering wheel brings the suck second only to the base Camaro wheel! They are both fugly!  |
Says the guy who likes airbag wheels! |
As an alternative to the base or IROC wheel? Hell yeah! Grant is the way to go.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Thu Aug 25, 2011 8:31 am Post subject: |
| aaron_sK wrote: | | fiveoformula wrote: | Im starting to think you just like to lock your self in your garage with a few cans of paint all day for the fumes.  |
Blargh! I hate paint fumes.
| blue89 wrote: | | Nice progress! When does the cage go in? Can't have a sheetmetal dash in a t-top without a cage. |
Haha, no funds for that now. I would love to run a cage and tie it into the strut towers and SFC's, but as they say, your money's money is all that moneys.
Says the guy who likes airbag wheels! I will probably be looking at a Grant down the road, but I have the IROC wheel in hand.
| Twilightoptics wrote: | | Wiring looked pretty clean really. And Amplifier wire can handle a lot more current than battery cable for the same size or smaller. |
Looked being the operative term. The car cranked so slow it would barely start. That whole install was bad-news bears. |
So did mine after my battery relocation. Turned out to be a junk starter. _________________ A redline a day keeps the carbon away! |
Posted: Thu Aug 25, 2011 11:42 am Post subject: |
Spins like a champ with the battery up front and running cables stolen out of the Monterey.  |
Posted: Thu Aug 25, 2011 11:56 am Post subject: |
Ahh. _________________ A redline a day keeps the carbon away! |
Posted: Thu Aug 25, 2011 7:02 pm Post subject: |
Updates!
First off I would just like to mention that when you buy a car that is completely gutless, and you find a box of old plug wires in the back seat, it's probably worth sticking your head under the hood to make sure that the numbnuts in there before you didn't swap the two and four. The Banana runs pretty damn good now with no weight and all six cylinders. I was so pleased by this I brodied for half a block.
Some other random notes from the shop:
I've posted here before about GM blower motors and the different sized squirrel cages you can run in order to use an aircon motor on a delete box, and this is what I'm talking about:
The delete motor has the black cage, the aircon one has the white cage. As you can see the shaft for the aircon motor is much longer than the delete shaft. The aircon cage has very long blades, too long to fit in the delete box. You need to hit up FWD cars in the junkyard till you find a cage like the white one in the pic with short blades and the provision for the long driveshaft.
The reasoning behind this is to get a larger, and presumably heavier-duty motor. Note the size difference in the cases, which is reflected in the windings. One issue is the air inlet for the motor. In the pic below you can see the issue. This can be resolved by getting several bypass tubes from the junkyard and joining two together.
And that's enough about shafts, on to petals!
Anyone on TGO who tells you you can't mix and match third and fourthgen pedals has cousins for parents, 'cause I just did it:
All that stuff about different sized shafts on the clutch pedal and whatever is all a bunch of bull. The master cylinder is about a quarter inch diagonally down and to the left vs the thirdgen one, but I did not even need to ream out the holes, there was enough slop for it all to fit together nicely. The clutch engages a little bit lower, which I prefer to the thirdgen style. It also pushed the clutch pedal over to the driver's side an inch or more which is really nice when you wear size 11-2E workboots.
This is how she sits as of this evening:
Now I've just got to convince myself to start cutting into a working harness, and to pull a running engine. Stay tuned! |
Posted: Thu Aug 25, 2011 7:52 pm Post subject: |
Nice! Now get that motor out! And then we can have a race to completion.
-jake _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Thu Aug 25, 2011 7:57 pm Post subject: |
| 83Z28BlackBetty wrote: | | race to completion. |
Only if the results are weighted against an actual race once (if?) I ever get done.  |
Posted: Thu Aug 25, 2011 8:01 pm Post subject: |
| Deal! I'll take on your puney 6 shooter with a squirrel cage! Don't mind my 3 month head start... |
Posted: Fri Aug 26, 2011 7:07 am Post subject: |
| 83Z28BlackBetty wrote: | | Deal! I'll take on your puney 6 shooter with a squirrel cage! Don't mind my 3 month head start... |
Better watch it... this could be the next tutu bet.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Fri Aug 26, 2011 9:22 am Post subject: |
LOL Jake is going to lose.....
WHOA Pink Betty, Bam Ba Lam _________________ A redline a day keeps the carbon away! |
Posted: Fri Aug 26, 2011 11:24 am Post subject: |
tu tu tu tu Tu Tu Tu Tu TU TU TU TU!
Fresh Princess... Woot!
Posted: Wed Aug 31, 2011 5:32 am Post subject: |
AHAHHAHA, No way, this LT1 is going to have a billion horsepower. nothing will beat it....  |
Posted: Wed Aug 31, 2011 6:13 pm Post subject: |
Those GTA seats were probably really nice at one time.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Wed Aug 31, 2011 6:31 pm Post subject: |
Are the accordions good on those seats.. and if so.... you going to use them?  |
Posted: Wed Aug 31, 2011 8:48 pm Post subject: |
Not sure, B. I will probably keep the accordions, they are sweet. I really love these seats, they are comfortable and totally unique (my two favorite things ).
They are too heavy for my flyweight taste, but I'm thinking of gutting the air crap out of them. Think I'll wait till I have some ass-time in them before I decide.  |
Posted: Sat Sep 03, 2011 1:11 pm Post subject: |
| aaron_sK wrote: | Not sure, B. I will probably keep the accordions, they are sweet. I really love these seats, they are comfortable and totally unique (my two favorite things ).
If you're parting the seats, can I get dibs on trhe head rests?  |
Posted: Sat Sep 03, 2011 1:39 pm Post subject: |
Bah! Not parting out GTA seats!
I just mention that I was considering removing the air system and whatnot to make them lighter and you guys are in here like vultures.  |
